CUTLASS Need help
tiwii666
21
2
24
Canada
Hi i want to remove my oil pan it is possible to remove without lifting my engine?
  • Wow
Reactions: RICKDIZZLE
It can be done with out pulling the engine but you will have to jack it up and put wood blocks in the motor mounts to hold the engine up while you change the pan. Never jack the engine up by the harmonic damper or the pulleys you can break the crankshaft.
What am i seeing in that picture? KInda looks like the PCV clean air tube jammed in between the starter and oil pan.
Are those transmission cooler tubes folded into a damaged pan? 🤔
