Need pics of 403 with A.C. Vbelt
Sorry it came to this. The Vin Y A/C setup extremely difficult to convert to non A/C. The Vin 9 set up uses the triple groove crank pulley along with a dual groove power steering makes it super easy.
Its ok. After working on it for 7 hours....multiple trips for belts and bolts. I finally won!
  • Winner
Reactions: TURNA
Washed it. Took it for a spin. Tightened the bolts again and checked belt tension. Then my step son and I went for a 20 minute ride. Im glad its back together and running! Thanks guys for all the help!!!! It helps me out everytime i get in over my head!
Pretty sure one of us Olds guys will buy that passenger side bracket off you if you can't return it. Awesome, it is running again. My 70 Cutlass S is sitting, no brakes, so I know how you felt through all this.
I would sell it. Im not gonna use it. It would take to much work to make it work with my stuff. Im happy with how it is now. I have extra spacers and bolts too
I hate seeing the car sit and in pieces. I got it going just in time for some better weather tomorrow. Gonna drive it for a while and see what happens
Reactions: olds307 and 403
What groove on the water pump and crank pulley does that bracket line up with?
This was without any of the spacers. Only used spacers on the 1 WP bolt to keep the bracket straight up and down
This is with the original spacers they gave me
This is with the longer spacers i had to use to put the pulley back on the far groove on wp since the power steering wanted the middle groove.
