Need SBC installation tips please...
Have you considered buying a standard olds block 350, 403 amd putting all your olds stuff on it?
The old saying from Summit where it or they won't fit the cutlass supreme..IIRC they are actuallu referring to the A body era cutty's.....Check out the Flowtech afterburner headers....they will fit nicely in your cutty ( only woth a SBC) of course....and if you have the 200 crossmember, if I read your post right, you can use that crossmember as long as you get a tail shaft for a mid 80's caddy or caprice....check out this thread : http://www.montecarloss.com/community/u ... Post762415 and this : http://www.rowand.net/Shop/Tech/Automat ... onSwap.htm You will ove the 700r4...Well, I do anyways....I went with the BandM Pro Stick for my shifting needs..Good luck and keep us posted 8)
