im running a stock 350 bottom end, just had the stock heads machined for screw in studs and had a pocket port done on them. the machine shop said it would add more power that a gasket match port. i had a head improvement kit from competition products intstalled. new valves springs rated to .510 and new valve seals. all new locks and retainers to. the cam im running is a flat tappet .465/.488 282/292 duration. and i plan on using a dual plane intake. now im trying to choose a carb. i was thinking a 750 vacuum secondary carb with an electric choke. on my ford stroker motor im running a chokeless 750 dp mech secondarie but i only use that car on the weekend to go to the car shows around town and rarely at the track since its kinda far and i dont have a trailer to pull it there. but i think it will be overkill on this car since i plan on using it during the week just to roll to work in somethin that has some power. the machine shop is saying 650 but would that be to small if i decide i wanna take this car to the track and run. im not concerned about gas mileage either. and i want to try to the the a/f ratio at 11to1.
