So...I've had subs hooked up with the original 307, no problem. I've had someone else swap in a 350. Went to hook my subs back up today and here's what happend...
Hooked up everything like it was before. I have a negative battery terminal disconect with a 15amp fuse so I won't lose radio settings when I disconect the battery to work on motor etc. I had blown the fuse because i forgot to turn the knob before trying to previously start the car. When i went to replace the fuse it sparked and instantly blew the fuse. I disconected the negative terminal, put in a new fuse, and turned the knob the connect the neg back to the battery...big spark, fuse blown. Looked at my capacitor and there were no power lights. However, i decided to see if the stereo still worked and it did...and the subs were working also. I turned off the stereo, disconnected the negative terminal on the capacitor and it powered up with 12 volts showing. I went to replace the fuse in the battery diconect terminal and it sparked and blew instantly. Capacitor power display went off. went to hook up the negative terminal on the capacitor and it sparked. So i dropped the cable to the trunk, and noticed that the capacitor power display was back on but only showed 8 volts. I disconnected the power cable from the fuse for the subs, connected the negative terminal to the capacitor and then reconnected the power fuse and the capictor display doesn't power up and the subs aren't working. WTF should I do to fix this...and no I didn't have any electrical problems (that i know of) before trying to hook up the subs. I'm at a loss...
