i just got an 84 H/O that has sit outside and not running since 93. i have most stuff working and running now but need help with the lightning rods. there is a little "spring ring" that holds in the button spring on the bottom of each lever. two of these rings are broken. this shifter looks great and even function great on the main shifter but the 1-2 and 2-3 shifter have these rings bad. where do i get these rings?
i also need the drivers door latch mechanism that mounts inside the door. this one was rusted and i had to break it through the window channel to get the door open.
thanks for any help you can give, i will try to post some pictures tonight.
