that's a pretty big cam for the street. quite possibly too big. for the strip it'll be good though. for some good performance and idle i'd stay smaller than the xe-274, a xe-268 would be real nice.
again for the street, i'd go with about a 180 or 190cc runner, 2.00in intake/1.6in exhaust valves. you could go with 170cc runners but that may be too small for your power requirements, and definately too small for a 280 cam. but there are a lot of choices
http://store.summitracing.com/egnse...1+4294867079+115+4294867028&Ntk=KeywordSearch
the quench distance i mentioned does not depend on what heads you use. it's just the distance from the top of the piston at TDC to the top of the head gasket/base of the head.
oh and the roller cams do not require any block modifications, that's why they're expensive. but they are more reliable. flat tappets have MAJOR problems with todays oil and will be destroyed if you do not run a high ZDDP content oil/additive.
