New from central Washington
xxBLOOD88SHOTxx
142
164
36
Hello people, just picked up an '82 Regal with some sort of 350 swap for pretty cheap. This is my first RWD V8 vehicle. It is not it the best of shape but it is just something to have fun with. I have always had a weird thing for G bodies and this one was very local so I got pretty lucky with it. I have had lots of different cars over the years but I finally pulled the trigger on an old school American V8. I look forward to hanging around the forums at odd hours of the night and spending money on things that I shouldn't :banana:
Welcome and good luck with your project
Reactions: xxBLOOD88SHOTxx
Welcome. The whiteout trim and wheel choice leads me to believe that it was a pretty sharp car in the late 80s. Any info on the Olds engine?
Is that what it is? Like an Olds 307 or something? I can’t identify these things by just looking at them. It doesn’t matter what is in it right now anyway lol.
Reactions: Emmanuel cuellar
I didn’t look into any of that last night I just dropped it off and the shop and went to bed. I was about to head out to look over all that stuff.
Reactions: DRIVEN
Nice Regal! What is the number stamped on the bottom left of the head below the valve cover? That should give you a starting point to which small block Olds you have.
I will have to clean it off and check it out tonight. I did climb under it and look at the rear end which still seems to be the lame 7.5 inch.
Ultimately want to do a 4.8 or 5.3 LS with a properly sized Holset. Not sure if I want to do the typical all white or maybe white with gray along the bottom to match the interior.
