Hi my name is Bob and Since its always good to try to get information from where ever you can get it I decided to register. I own a 88 4.3 v6 chevy monte carlo. Just had it pass inspection and it's still a work in progress and im still learning. After my inspection they told me to teflon tape the adapters for my oil pressure switch since they were leaking and i did so once i got it back from them. After i did that, it was running real rough till the point im at now...which is when i have the hood open from almost any point it'll run, the inside lights come one...but if i shut it all the way, interior lights cut out now and the fuel pump doesnt come on either only check engine light comes on with the hood shut and it'll crank but sound off? Ive done alot of work to this car(had the engine re built by a shop, trans and replaced most parts up to even a new ecm) and this is the oddest thing thats happend to me so far. today the only thing i messed with was the oil pressure switch and now all this odd stuff is happening. ill keep checking connections and hope for some insight, thanks!
