Newer gtp parts on 85 gp le
K
Kodyvan
5
I have a 2002 gtp sitting in back yard. Motor has a horrible knock. Are there any parts that might work with the 85? Interior/exterior?
Streetbu
Streetbu
1,527
Central NY
Front bucket seats will transfer if the 85 has buckets or even a split bench
Reactions: fleming442
Streetbu
Streetbu
1,527
Central NY
Easiest thing will be to get a wiring diagram for the gtp and then you'll probably have to wire a power and ground in to the 85. This is all assuming the 85 doesn't have power seats. If it does, should be a fairly straightforward wiring job.
565bbchevy
565bbchevy
7,187
Michigan
K
Kodyvan
5
Anyone know if wheels would swap out until I get something better?
Streetbu
Streetbu
1,527
Central NY
Nope, different bolt pattern and offset. I suppose you could buy adapters but decent ones won't be cheap
C
clean8485
2,453
Ontario, Canada
Basically, you're talking about 2 cars that are very different. There might be some other stuff you you could swap over, but probably not very much.
kiko
kiko
263
Ottawa, Canada
I agree with clean8485 because I used to own a 1999 GTP (bought it new in 1999 and sold it after 315,000 km in 2017), and I still have my original 1983 GP. There was not much that I would consider swapping. You could mod your G-Body to use the GTP seats (some effort required), or use the console, but the styles are quite different and would require much "massaging" to get the proper look. The GTP has a smooth, rounded look vice the G-Body which is more square.
Just my 2-cents.
Thread starter Similar threads Forum Replies Date
M G-Body Parts For Sale / Trade 19
J OFF TOPIC 20
MrSony General Discussion 101
O. D. Showtime G-Body Parts For Sale / Trade 3
Hubb79 Interior 1
