ok so my headers are like way too close to my plugs and plug wires with these heads and ngk plugs. so much that you are not cannot install 2 of the plugs and wires without having the header loose.
Profiler specs to start with these plugs or colder
http://www.summitracing.com/parts/NGK-4091/
which is what i bought aqnd have installed now. With the wires on #1 and #7 plug boots touch the tubes. I have DEI heat sleeves on the wires so there is something between the header and the wire boot.
I noticed these plugs and are listed as shorties but are high dollar and a different material. im wondering if i should try them or something else.
http://www.summitracing.com/parts/NGK-4587/
heads require .750 reach and a gasket seat.
has anyone run ngk short plugs? how short are they?
