no fuel pump provision???
some of the blocks had the holes there and just blocked off my 88 truck is like this. my 89 truck was like that as well. but when i got a replacemt motor for my 89 out of a 93 it was not there. so not really sure when they stoped drilling the holes.
To my knowledge all Gen 1 small blocks were cast with the fuel pump mount. If it has a block off plate it will most likely accept a mechanical fuel pump. If it does not have the block off plate then you can't run a block mounted fuel pump as the block was never machined for the pushrod or the oil return hole. GM used the left over blocks machined for a mechanical pump till they were gone, then never machined the new castings for the pump at all. The vortec blocks will not be machined for a mechanical pump.
Like hurst1979olds said, even if you can mount a pump, it is unlikely that the cam will have a lobe to power it, requiring a cam change as well. It's not a big deal to run an electric pump with a regulator for Carb'd applications. I would also consider running the TBI- better mileage and can be modified with larger throttle bodies, etc for good performance.
There's also a jig you can buy from Engine Quest. You can drill an efi block with no holes for a fuel pump. More times than not I see them with pushrod and return hole partly drilled. I just fdrill them out myself.
