==========================================================================================================adam6640 said:Not positive but I believe the el camino/malibu/lemans/grand am front clip w/hood will work,the cutlass wagon is the same body as the malibu wagon,even the lemans wagon, the side body lines are the same , if your 80 cutlass cruiser is a double headlight model you could put the 87-88 olds cutlass single composite headlights in or a chevy celebrity headlight, you might even be able to put a lemans header panel and hood on it.
Good Luck
Adam,
I'm going to have to disagree with you. The Cutlass Cruiser body is not quite the same as a Malibu wagon, or Bonneville, Lemans Safari. They do not share the same lines. Olds would share lines with Buick. Chevy would share lines with Pontiac.
You could theoretically hang the doors and nose from a Malibu or lemans onto a Cutlass Cruiser. But then you'll have to deal with the continuing body lines on the quarter panels, which will take some creative sculpting/ metal work.
Anything is doable.
