Oil Pressure Kill Switch
censley
Jun 30, 2012
77
Hey Fellas,
I'm about to drop my performance engine in my 442 but I need to install a kill switch to build up enough oil pressure before I start the engine. I have no clue how to do this or where/what type of switch to get
Please advise...
Thanks!!
Build up oil pressure before you start it up :?: Are you talking about priming your engine or actually just build the pressure right before you fire the engine :?:
Are you running some type of dry sump system :?:
If you are talking about a killswitch that shuts the engine down,in the event of an oil pressure loss, they are pretty simple. You need a Hobbs switch, readlily available from NAPA. they are adjustable. There's an socket head under the rubber plug. It is a normally open switch that closes on a rise. You run the main power wire to your ignition through it. If you are running an MSD 6 or 7 box, run the switched power through it, not the battery power. They don't handle much in the way of amperage. Also, you will have a more difficult time starting, as you will have to crank for oil pressure before you get ignition. I paralleled an ignition feed to my starter solenoid, so I would fire immediatly. If you do this, you need to add diodes, to keep from back feeding your starter after firing. Sounds complicated and it is, but it's worth it. I was racing and tossed my dry sump belt. My motor shuts down at 40 PSI of oil pressure. I was spinning around 7000 RPM, you aren't looking at all of your gauges when you are driving competively and oil pressure goes away fast. Saved my 588 in the boat.
Yeah, the engine has no oil in it. I need to build up oil pressure before starting it.
I may be wrong here, but i'm fairly certain that there is no "switch" to prime the oil before starting it. I use an old distributor and stick it down in the hole and use a drill to prime the oil pump until oil comes from the pushrods and goes back into the valley. But then again i may not be understanding the question...
To prime the oil system before intial start-up, you need to buy or borrow a Chevy oil priming tool. It just goes on your oil pump pushrod and you spin it with a drill. As soon as you have movement on your oil pressure guage, you're good to go :mrgreen:
http://www.youtube.com/watch?v=tOYLlr8uQ8k
