My 78 Cutlass Calais 260/5 speed finally arrived today. Had about 10 whole minutes to look it over and noticed 2 things I thought were weird so here's my 2 questions;
1) Car had the carb rebuilt but I assume it's the actual factory carb. Carb has an idle kick up solenoid on it BUT the car is a factory non AC car. So did some idiot add one on or is it supposed to be there?
2) Temp sensor has no wire going to it. Needless to say the temp gauge doesn't work. No loose wire to be found for it BUT there is a single green wire plugged into that idle kick up solenoid I mentioned above. I'm wondering if the green wire is actually for the temp sensor. So is a single green wire correct for the temp sensor with rally gauges?
Overall I'm pretty happy about my purchase even though I only drove it from my driveway into the garage so far! Car is super clean and all original with only 14k. Can't wait to get some Olds rally wheels and rwl tires on her!
