I bought a 88 cutlass supreme classic last week with a built olds 350 and th350 trans out of a 72 cutlass. When driving it the belt squeals horribly and at idle it's fine. The previous owner put aftermarket 2 groove aluminum pulleys on the water pump and crank. I searched the forum and learned about the famous ac delete then the belt squeals issue. What I'm confused on is if I get a bracket to move the alternator to the passenger side I'm not changing anything besides the location of the alternator because I only have the 2 groove water pump pulley and crank pulley. What do I need to make this setup work? Right now Im embarrassed to drive the car because the belt is so loud. The previous owner also told me that he put a bigger water pump on. How do I know which one it is and could that have some affect on the problem? I can post some more pictures this afternoon if needed.
