I have a 86 cutlass and i have 1972 350 rocket motor i want to rebuild it. but should i rebuild my heads or should i buy the edelbrock performer rpm heads their $820.oo each. i want my motor to be strong but are they worth it?
Vern said:There are half a dozen well known Olds specialty vendors or shops across the country that specialize in building Olds engines. I would talk to one of these vendors and see what they recomend releative to what you have and your goals. Power is in the heads so as long as you are not going past your bottom end capabilities spend your money on your heads before anything else. I believe people have trouble with the electric fuel pumps with the aluminum heads on the small block although I think somebody made a solution. Even if you buy the aluminum you should have some light clean up port work done by someone that knows where they need a little help. I think you will find that pro ported big valve rebuilt heads with bronze guides & good springs etc will cost you almost as much as the aluminum before you clean up the aluminum heads.
