Do the math on the aluminum heads if u want to go that way before you even start work on those. I found out that it was only about a 20 dollar difference from rebuilding the stock heads and buying new aluminum heads. Plus the aluminum save 50lbs of weight off the front end just on the engine. By the way a big block olds motor is less weight then a big block chevy any day even if both are stock.
