Olds water pump/impeller
pizza442
13
I've always understood that the 'disc' impeller was ideal (and OEM?) vs. the 'vane' or fan-like impellers. Opinions? And when I take my original pump off my 86 442 will I find a disc impellor?
Oct 14, 2008
6,382
Melville,Saskatchewan
It SHOULD be the enclosed vane impeller. Anything with A/C and heavy duty cooling had the enclosed impeller. I pulled a nice cast iron one off a 260 and used it on my 350.
6,382
This the one I got for my 403 with AC and HD cooling
Pretty much the only enclosed impeller pumps being made are Flowkooler. They used to just rivet a plate on the open impeller, leaves a bunch of room between the impeller and body. Mine did nothing to help cooling, would not surprise me if it made it worse. Now they have a nice CNC close fitting aluminum impeller that no doubt works better. You want more flow with less cavitation, a tight fitting closed impeller should do that.
Drkuhar
297
Watch aftermarket pumps.for finned impellers that are too small for the bevel. They do not cool right. I found 2 at autozone with the same part number and the impeller fins were about 5/16 shorter on one vs the other
