C'mon dude, we need measurements down to the micron. Preferably in both metric and standard. Oh, and thickness. That washer looks bent like it was over-touqued. Did you youse touque it? Did you use a Craftsman model 1019 Laboratory edition, signature series torque wrench. The kind used by Cal Tech High Energy physicists, and NASA engineers. And how do you know that was accurate? Because a split second before the torque wrench was applied to the bolt holding that washer, it had been calibrated by top members of the state and federal Departments of Weights and Measures, to be dead-on balls accurate.
Dead-on balls accurate?
It's an industry term.
I see what you did there.
The side rear washer to the block for the power steering bracket is thicker than the one shown as I remember. Can't say for sure, but that looks like the washer that goes behind the adjustment bolt for the power steering if it indeed is coming off the front of the engine in that area. That's my guess. If it's for a 7/16" bolt size that's where my money goes.
