Oldsmobile Quadrajet flexible fuel pump to carburetor line
kustomkyle
646
47
Looking to see if anybody has converted their main feed line to braided flexible type?
I like the hard line, but if you ever go to change the filter or pump, it's a day of trying to get it threaded back in IF you don't cross thread something.
For example, an Edelbrock 8123. Just can't do many (or any) adapters since the front feed carburetor is very tight to the thermostat housing.
And to clarify, I'd be looking for something with the factory inverted flare fittings. The factory tube is just a 3/8 brake line bent to fit (though it is almost impossible to make yourself with the right bend at the carburetor end).
That might be hard to find ends that will seal properly. I need a custom one for the serpentine belt drive, it hits the stock steel line. I tried bending Ni Copper line but the bends are both very tight, even tighter than stock. I looks like sh*t currently.
From what I gather, the ends to the braided hoses are like a compression fitting. So, it would just be a matter of finding the ends that are made to be whatever thread a standard 3/8 brake line would be. As opposed to AN or pipe thread.
I guess the problem is most people who use non-factory style parts go all the way with everything as far as modifying. Holley instead of a CCC Quadrajet. If not fuel injection out of a box.
Yep, very easy and highly recommended
Thing is the CCC Qjet is superior to aftermarket carbs for most uses. The quality of many aftermarket parts including so called performance parts is often not as good as OEM parts.
I unbolt the carb from the intake to remove the fuel line. Start both fittings before starting the carb bolts.
That would be a way to do it. But that's also like unbolting a door and bolting it back on every time you get in and out of the car.
I would agree just with what I've experienced driving the car every day more or less for 15 years. It's not a hot rod or toy. That being said, if I need to change the fuel filter, or plan on doing it proactively, having the car down a whole day to do something simple is where factory things need "reengineered".
Nearly every Olds V8 I had, the line at the carb was severely twisted when I got it😥.
