Check Classic Tube. I bet they reproduce it in both regular steel and stainless.
Yep, pretty sure they don't, these are the guys on Summit I was hoping would have so I could get it in a couple days. All they had (that I've found so far) is for 1977 and nothing newer for the B.O.P. engines. Tried 1978 and newer, but Classic Tube wasn't even a search option. Just fuel line and brake line kits for the chassis.
In some older posts I've since found, there apparently was even a different one for the
H/O Cutlasses in 1983-1984 (!?), why I have no idea. There physically wasn't anything different on the outside of the engine, and you can't really go any bigger than the 3/8" a VIN Y line would have been anyway. But, there seemed to be a different bend configuration for some unknown reason.
Looks like Inline Tube is the company that makes them for the later models, or did anyway. The VIN Y/late VIN 9 part number I haven't found anywhere for sale at the moment. Inline tube has a website, but they only seem to have a paper catalog that you can order from (?). Still trying to figure that all out. Haven't found any leftover N.O.S. GM ones either. You wouldn't think a part, especially like this, would be that hard of an item to find, considering the engine was primarily in the best selling vehicles in the country for over a decade. Wow.
I've also since attempted to make one out of a 3/8"x20" (it is, in fact 3/8" inverted flare brake line), but was unsuccessful. I made half of the bends coming out of the fuel pump area, and it looked fairly decent. However, there's not even an inch of line coming out of the fuel pump before you need a 90-degree bend. I was able to get about 1-1/8" into the tubing bender and that was pushing it, but that 1/8" is the difference needed to clear the A/C compressor bracketry. The factory fuel line also seems to be about 17" total in length, so I would need to cut and re-flare one end. Maybe someone with better tools could do it, but right now it seems pretty impossible.
All this when all I was trying to do was change a fuel filter.....
