On the Cheap chasing an 8.50
I bet IATs were money.
They were cool as expected. But basically the difference in ambient temps. The meth injection is going back on so that in the heat I can keep them sub 180, and hopefully sub 150.
Been plugging away. 1st item on the agenda was dropping the trans pan to see what kind of surprises were in there for me. If it was ugly, then that means a trans freshening will be required which implies $$$$. Fortunately, the transmission gods were watching over me and the pan contained nothing metallic and virtually no clutch material. I was truly shocked and happy. This means that I can wait until mid to late summer to reassess before DW.
I have a list of areas to improve. 1st, is adding some rear end geometry adjustability. I bought some brackets for a Fox 8.8 from MAF Racing and modified them minorly to have them act as 'doublers'. Here is the before :
And here's the after :
I was able to re-purpose one of the original holes and had to drill the remaining 32. This started out seeming like a relatively easy process, and as usual, I was wrong. After drilling and reaming the top 3, the bottom 5 on each bracket required a right angle drill ......... all I'll say is that sucked. But hopefully the end result will be worth it. I can now change my antisquat percentage in 9% increments from 95% to 175%. And if I move the upper bar I can change the Instant Center length in 5-6" increments. Hopefully this will let me get the chassis to work on radial prep to no prep surfaces with just some bar changes, shock changes and weight adding.
Next is onto the parachute. If I haven't mentioned it before, the DW people and track folks during DW were giving me some heavy sheetz about not having a chute running over 150. I had a plan to fabricate a mount and work at getting it in the correct location to get it through the bumper. After reading too much and overthinking the situation, which is my usual modus operandi, I found Trick Chassis makes a direct bolt in chute mount for $250ish. So I pulled the trigger on it. I want to say, Alex (owner) is a fabulous guy and his products fit. I bought a tube core support from him in '22. When I ordered the chute mount he had all of my information and history in his computer system. I ran him through the ringer getting me measurements to confirm that his piece is a direct fit. And he didn't bat an eyelash at offering up the info. I had the part 4 days after ordering. Here's what it looks like :
It is amazing the amount of crud/buildup behind the enduro bumper. I've since cleaned it off. I dropped off the chute mount and my homemade hitch to be powdercoated. I should have them back next week for the small sum of $200. But I think it will be 100% better than me using a rattle can on them.
For those of you that haven't seen photos of the SSM 8.8 truss kit installed, here's a good one :
A friend told me that it looks like Killdozer piece lol. It's a chunk and not easily slid around on a jack. And it's not a weight saver, but it's tough as hell. Not pretty, but effective and budget friendly as well.
The remainder of the winter upgrades consist of a cam swap, re-working front a-arm geometry, and a converter re-stall. I'm hoping that these will get me the last .3-.4 to get me to 8.50 in a full interior street car. Time will tell. Fellow member Jdam has offered me an air launcher cylinder for the chute so that I don't have to mess with a damn spring launcher for repacking, and it's appreciated beyond what I can say. And I urge you guys to look at the Trick Chassis parts - Alex and his wife are the real deal - honest, hardworking people making quality parts for our cars.
Happy trails - Jim
As always - took longer than I thought it would lol. The powder coating turned great - as it should. Getting the damn enduro bumper reinstalled and aligned correctly was an *ss ache to say the least.
Cutting the hole in a very good condition bumper had me cringing. At least I got the hole in the right spot on the 1st try.
Still plugging away.
I pulled the heads and swapped the cam to Stage 4 Lunati turbo cam. I’ve only started the motor and idled for a short bit, but it runs. I ran a compression test before pulling the heads and all was good. When the heads came off everything looked great. I’ve relocated the turbo to hopefully get a better supply of ambient temp air from behind the headlight. I refabbed a new hot side in an effort to have better WG placement and replace my rusted 4 year old pipes. Installed a 2nd small, 12x12, trans cooler with fan that I had kicking around. Put the meth pump and a new tank in the trunk - still have to plumb it into the intake piping.
I’m working on the front end geometry presently. And all I’ll say is ‘what a pita’. But hopefully I can get it figured out (I’m sure it will be better.) I ordered some new front springs today from TRZ. I’m living a learning a ton from some vendors and local friends helping me to get it working better. Pulling the 300lb and putting in 450’s.
Some welding on the new intake. It’s not visible in the pcs of the 1/8 npt ports added in accessible areas - rather than underneath the intake.
Those of you that have followed along with the car, you know that I’ve mentioned numerous times of changing goals……..because ‘it’s never fast enough.’ Well, I’m going to try to get to the cage certification - it’s going to run an 8.5_ if it kills me (hopefully the car doesn’t haha.)
Drag Week 2025 will hopefully be the end game of being competitive in the 8.50 street race class.
Any news on getting in on Sick Summer or did you bail out on the wait list?
Cool to see the updates and the Monte Cat-lo
Still waiting for an email.
