I had recently converted over to a 1994 truck serpentine set up using the alternator which is a one wire I need to try to figure out how to wire mine down from three wires to one. I am not that good with wiring but thanks ahead of time if you can help
Tape off the other two connectors and hook the battery connector and done. Realize it will probably need revved up to charge. Is there a plug on the extra terminal? Many one wire alternator can be both.
