have you looked at the system?!?!?!? remember about 4-5yrs ago when ONE power station went down and took the entire eastern half of the US with it? the system is designed so that when one section goes down the load shunts to other sections. this way the areas with a power loss is minimized in the event of a failure or a plant going down for maintenance. the system was also designed in the 20's or 30's for a predicted output in later years. their prediction was based on US growth statistics, unfortunately they were blown away by the actual growth, post WW2. and the system WAS NEVER UPGRADED!!! yes it was added on to, it's like adding a supercharger onto your 11:1comp engine without lowering the compression. sure it'll work, for a little while. when the system was operating at peak power output due to hot weather and one plant went down the overload went to the next system, which was already at peak. so the safety sytems shut down the that system to prevent a burnout and it spread like ripples in a pond.
look at the power problems they've been having in california the last few years. the only "good" option without a complete system redesign is to make a bunch more small power plants (but we can use green sources for this) and a "circuit breaker" setup. this way when one area goes down, it's the only one and the area's size is limited to that of a smaller station. or we need to start building nuclear reactors and LOTS more power lines.
it's much like the bridge collapses, last year the infrastructure was never upgraded like it should have been.
so you know, this is something we were taught about in my nuclear field electricians mate a-school. (this was long before the massive outage, but they had taught us about this weakness and why it was there.)
