Oxygen regulator questions
Nick, that trick came in real handy for me. I had a cracked Pontiac exhaust manifold, right where the head pipe bolts go. A big chunk had broken off one of the outside lips where the threads are. I inserted a bolt where the threads used to be, I then used the cutting torch to melt the iron, then added some from an iron rod, using the torch pressure to move the molten blobs around. The bolt was encapsulated by the iron, but that was fine as then I could just use a nut down below. It was ugly, but it saved that manifold. I think I even still have that manifold around here somewhere.
Problem with the new regulators! With the old Craftsman ones you had to screw the knob in quite a bit, then you heard the diaphragm go pop inside, and gas flowed. I hooked these to the tank, opened the valves and gas was flowing! YIKES! Well it turns out you must FULLY relax the knobs, almost to falling off, because as soon as you screw the knobs in, gas is flowing. You can't anticipate it, it is that gentle of a touch. Note to self: back the knobs out ALL the way before opening the tanks. Otherwise they work great.
Reactions: Longroof79
Your state has an oxygen regulator? We don't have one in California, even. Yet.
(Sorry to troll. Can't resist the one-liners.)
Reactions: Bonnewagon
Oxygen Regulator in California? Well now that you've brought the matter up, some bureaucratic hack will likely try to have the position created by way of showing his/her/? environmental sensitivity, Wait, thought that was the job of the CARB although that could be more a case of them trying to control all the hot air emanating from Sacramento, or maybe from the fires?
