Parts from thirdgen camaro to gbody
87montecarlomrc
476
35
Oklahoma
What parts from a 82-92 camaro swap to a gbody, the gear box will which is better then the g body one and wat else will, does anyone know
Front sway bar
Lower rear control arms
Front and rear springs
Just a few of the items off the top of my head.
I new the springs would but didn't no the sway bar, will the camaros springs be better then my montes, I have an 85 camaro with a fully rebuilt suspension that use to drive so good but the motor compartment burnt up and melted all the wires and I'm wanting to get all the parts for my Monte that I can
Do the springs change the stance any?
1.-Front lower control arms (stops need to be ground down if wheels are smaller than 16").
2.-Lower rear control arms ( 1LE bushings,,,,10164152, can be used also).
3.-Front sway bars (36mm is quite rare), 34mm is the F-41 and performs the same as the 1 1/4" solid but is much lighter.
FYI, 1,2,&3 are from 82-92 F-bodies.
4.-Aluminum rear drums from the 82-84 F-bodies.
5.-Aluminum radiator (5.7 auto......Modine 951).
6.-The XH steering box for 16" wheel upgrade
FYI, 5&6 are from 87-92 F-bodies.
7.- The serpentine belt drive system from the 88-92 F-body (can use the alt., p/s pump, A/C condensor, and the compressor and lines).
This info is from the site BOWTIEPOWER.COM
Doug
We should put a footnote on this that this only works if they have a Chevy engine in the car.
