Hey guys,
So I recently went with an A/C delete along with the smog pump and got the infamous belt squeal that comes when you do this mod. For a while it was more or less livable after changing the belts. I got it to a point where hard accelerating it or a cold start is what causes it to squeal. I tried the candle wax trick, nothing. Then I tried Murray's Pomade
Yes the hair pomade. That worked pretty good for a bit, but then I suppose the pomade would melt away and then I would recoat it. This last coating was pretty thick and seemed to work for only a little while. Now it will squeal most of the time when I moderately accelerate it. Woulda been a nifty trick if I got it right.
ANYWAY....
I wanted to know about switching the alternator on a factory Oldsmobile 307 to the passenger side as I hear that's the best way to get rid of the squeal. What am I looking to buy? Mounting brackets are a must, however do I need to look into getting a new alternator as well? What other hidden kinks might I get myself into when I attempt this?? Thank you!!
(EDIT): Will mounting brackets for a small block Chevy work too?
ANYWAY....
