How difficult is it to replace? Apparently the elbow is cracked, and won't pass smog without replacing it. Seems like it's fairly easy to remove, but thought I'd get someone's input before doing it myself.
Also, any ideas what would cause an engine to produce a high hydrocarbon reading? My 88 Cutlass Supreme (w/a 307 engine) failed the smog test because of a 102 reading @ 15mph. FYI: The max HC allowed in Ca is 93, with 53 being average. Interestingly enough, it passed the HC test at 25 mph, but not by much. Average @ 25mph is 39 with 63 being the max. My measured reading was 62.
On a side note, I had the dealer pour some liquid in the gas tank to break down some chemical buildup in the gas tank and carburetor. I wonder if this would cause a high HC reading?
