Hello, had a quick question for any experienced engine builders out there. I was wondering how much variance you typically see in assembled piston deck clearance. The reason I ask is that this seems to heavily influence the real compression ratio of any combination. I know I could calculate the tolerance stack of (most) of the components that play into this. For example, I use a Merlin 3 iron block that was race-prepped, with a deck height of 9.805 ±.005. The other components influencing the stack would be the crank stroke tolerance, rod bearing thickness (Clevite 77), connecting rod center-to-center distance (Howards), piston pin-to-top distance (TRW l2239NF). It has a GM forged 396 crank (don't know the stroke tolerance on this). I believe I have the tolerance specs on all the other components with the paperwork that came with them, I'd have to look...
When I assembled this engine (7 some odd years ago) I think I quickly measured it with a metal straight edge and feeler gauges, and didn't jot down the measurement. I remember there was some clearance (still some small volume between the block deck and the flat portion of the piston at TDC (these pistons are domed). Just curious if anyone knows a working tolerance on piston deck height, since I can't measure it now without tearing it apart (not an option!). Thanks for any insight. trying to determine how much more power potential i have....
Kevin
Kevin
