Piston To Head Clearance
565bbchevy
9,764
13,131
Michigan
Having problems getting the heads on, they keep hitting the pistons not sure why.
Maybe thicker head gaskets and longer head bolts will solve the problem.
You might consider an adapter gasket...
Just mill the tops of the pistons a bit LOL
Guy
Reactions: mobileaudio25
So if this is like the ones they make for wheels I should be able to bolt the completely wrong head on for my application... SWEET !!
Reactions: Opie Knievel
That's it...All you need is a "Cylinder Head Lift Kit", I'm sure Auto Zone or NAPA carries them or knows someone who does!:rofl:
I have this bitchin' welder I can lend you if you want to cut a chunk out of the rods and weld 'em back together
