Poly body bushing ?
Yea this is a nut and bolt lsx twin turbo resto! I just wanted to know exactly what was there when I started even though it was a fairly rust free 60k mile GN!
DO NOT LUBE THE BODY MOUNT BUSHINGS! As stated above they are static, if you lube them then they won't be as static which is bad. You don't want those bushings to move at all.
The famous poly squeak is from using poly bushings in the rotational suspension joints as opposed to the static body mounts. They squeak in suspension joints because they are binding due to lack of required deflection for normal operation. Lack of deflection isn't a problem for body mounts which is the only place to use poly.
