joe_padavano said:gs dewd said:As far as temp it could be the heater core is plugged and the water is just flowing across the top. If both heater hoses are the same temp with the heat on, that is a good possibility as the heater core should cool the water down a tad as it passes through with the heat on an fan running.
That's certainly a possibility, however the blend door bellcrank is a very common failure and is very easy to check. Pull the glove box and look at it. If it's working, then the problem is likely a plugged heater core. If the bellcrank is broken, a new one costs about $8.
Yes check the bellcrank first as he said. It could very well be that.
