You have to apply an acid etch before painting clean metal with por 15, something like ospho will work.
Epoxy primer with a topcoat will last forever. I used kbs coating system(not 2k), with rustoleum as a topcoat. I can't complain about it, it's hard to remove and was easy to apply, but if I were to do it again I'd use epoxy primer and a cheap topcoat that I could easily repair.
Surface preparation is all that matters When you do it this time. You need clean metal. No dirt,wax,grease,road grime etc. Plus 80 grit DA scratches. Or by hand....
Also, just an observation but those parts look really shiny in the pics. I'd make sure everything has 80grit DA scratches so whatever paint you use has a good tooth to bite into. The high speed from grinders, rolocs, etc kind of polish the metal imo. Rktpwrd am I wrong, I dont wanna give him crap advice 😆?
Wire wheel most definitely won't work, it really polishes the metal.
