Power door lock help
Ridgeline
131
I have a problem with my power door locks. When I activate the driver button I hear a click on the passenger side and nothing on the driver side. I have power to the switch on two leads and the actuator works when I jumped it with another power source. Are there relays or some other thing that would cause this problem?
Thanks[/i]
Could be a burnt out motor. I would test it with a light to be sure it was getting power when you hit the switch. If so, you can rule out anything else and just replace the motor. The relays, if you need to access them, are located behind the kick panel in the passenger's foot well.
