power steering problems
chicago2tacoma
102
So I removed the old .psp. from da 260 so I could put in correct psp wit bracket dat fits on da 350 sbc.....but when I took the old one out I cut the lines I cut close to the factory super hose clamp on the high pressure line for da pump my quistion is now how do I hook dis up can I jus use hose clamps or do I have to get those crazy clamps put bak on somewere....my buddy says there's to much pressure in that line to do anything else....give me a fix....
You can use clamps on the return line but for the pressure line go buy a new one. Hopefully you still have the old pump in case the new pump doesn't have the same style fitting as the gear box. You can switch the fittings in the pumps to make it match.
