BUILD THREAD Project ProbableCause #ABG
I would get 442 stickers for it and replace the middle 2 with a X.
Reactions: TeamProbableCause
WOW awesome!!!
And a hot momma too!!
I like the bed liner on the top !!
Reactions: UNGN
What springs are you running in front / back? Tall ball joints could help with the mad camber swings from negative to positive during hard cornering. That can make for a lot of understeer right when you don't want it.
Rear springs are progressive rate Vista Cruiser springs. Not totally sure on the fronts. I believe they are from either a big block, or diesel car.
I see Iowa plates, did you go to the SCCA ralleycross at CFMP couple weeks ago or somewhere else?
A good rear sway bar option is a '00ish 2dr 4x4 blazer, espeically since g body cars with rear bars in the yards are tough to find.
https://gbodyforum.com/threads/rear-sway-bar-fitment.51998/
It was actually a NE region Scca rallycross event. It's a little closer since I live on the West Coast of Iowa. Thanks for the sway bar tip!
