I decided to try out this Q-jet I had sitting around. Was rebuilt a while ago and used for probably less than an hour. Since putting it on, it took a very long time to start. It eventually did start, but after shutting it off it would not start again. The engine was running for maybe 5 minutes. Waited about half an hour and tried starting it. It eventually started, but still took a long time. I believe I had to have the pedal to the floor to start it. Took it for a drive and it ran really good. Great throttle response and ran very smooth. Seemed to be lacking power, but still will roast the tires. Hoping some adjustments can fix that. When trying to start it, I have been opening and closing the choke, but still doesn't want to start.
Is there any common problems that could cause this? I am sure It is flooded now, but there is still an issue with the carb. Any help would be greatly appreciated!
