I just got done putting a tilt steering column from a 81 cutlass in my 82 regal. Everthing swtiched out easy and then i tested everything to make shure it all worked. And realized that my front headlights and windshield wipers are not working. I started checking everything was connected and noticed on one harness from column that plugs into the harness to the car that they connect perfect but the wires on both sides are diffrent colors. Regal harness b-pink,c-black,d-grey,e-purple,f-green and the cutlass harness b-white,c-grey,d-green,e-purple,f-pink. If anyone has had this problem can you help me out.
