can you tell me what i need to hookup and what i need to cap. its for a racecar and ive already ran the vacuum lines i need but im not sure what is vacuum and what is not. also for the vent what can i do if i dont have a charcoal canister?
round track asphaltpontiacgp said:What you pointed out are all vacuum ports and need to be capped. If it's for a race application you don't need any vacuum lines so you might want to remove those tubes and seal the openings.The 3/8 tube for the charcoal canister should be removed and plug it with a brass allen head screw. What kind of racing are you doing?
matthew_rhodes said:round track asphaltpontiacgp said:What you pointed out are all vacuum ports and need to be capped. If it's for a race application you don't need any vacuum lines so you might want to remove those tubes and seal the openings.The 3/8 tube for the charcoal canister should be removed and plug it with a brass allen head screw. What kind of racing are you doing?
