Rebuilt a 17058241 qjet, (78 800cfm Buick 350 carb, same model and year yadda yadda as the one currently on my car) put it on, runs like sh*t. Won't idle worth a damn. Above the idle circuit it's fine, but the thing won't idle below 1100 without stalling or idling at 300rpm. It was an ebay find, and for giggles I tried it on the engine right when I got it, ran like *ss. Gotcha. Fast forward a year to today, finally got time to rebuild it. Found the passenger primary metering rod tip was broken off, either by me or someone else. I used a set of rods from a 17057252 Olds 350/403 carb. I could also basically cover the choke tower with my hand and it'd idle up about 300rpm higher, indicating it's lean... right? The two Buick carbs (old one and new one) are exactly the same, minus the primary rod change. I bolted the old one back on, flick of the key (bowl was still full) and she turned over like butter and burbled at 800rpm dead.
Tomorrow I'm gonna take the jets and rods and powerpiston/spring out of the old carb, put them in the new carb, and see if it changes anything.
Wish me luck.
Any input is appreciated.
Yes I checked for vacuum leaks.
Wish me luck.
