I installed a Holley 650 double pump mechanical my question is,I had a Holley 600 electric choke i was use to just cranking it up and it stays running then idles down to 850rpm,now the 650cfm is giving me an issue starting up,i have to crank it a few times and pump the gas a couple of times,and then it will start but i have to hold the gas at about 2000rpm for about a minute, to warm up then ill let it go and it will idle fine is this normal,and i have to adjust the timing a hair so my main question is this a normal issue switching from a electric choke to a mechanical one.
