I currently have the UMI rear uppers with the Roto Joint. The A body rear does not line up properly with the stock lowers which puts stress on them so I'll be getting some lowers with one Roto Joint. I'm thinking I might need a panhard bar to prevent lateral movement of the rear with having 4 Roto Joints. With the 4 Roto Joints the upper at the ears on the rear end and the frame location of the lowers are preventing the lateral movement of the rear end. I appreciate that the Roto Joints do not share the same axis so that would also prevent lateral movement but I don't have a program to test this theory as I don't know how much, if any, the control arms flex. I could test the rear end with the components installed but I was hoping this issue has been looked at by UMI...
Thanks
Thanks
