Doing a cam swap in a 350 chevy. 200cc Dart Heads, forged rotating assembly. I have 10.5:1 compression. Im going to do a magnum 304 cam. This is the description for the cam "Street/strip applications, 3000 stall. Use 4.10 gears and aftermarket intake & headers. Very rough idle".
I have a 4000stall and 3.73 gears. It does not specify if i need aftermarket heads or not so im assuming mine will be fine. can anyone confirm?
I cannot open cam specs due to computer issues so i cannot tell of the specs on duration, lift, or LSA.
