question on pvc and power brakes
cutty
207
near london ontario canada
new intake doesnt have a spot to hook up my power brakes,and running a 700 holley,where would or do you guys run yours to,i got my pvc hooked up to carb, any idea's
pvc
why don't you put a tee in line with the pvc.....jesse
you should run the brake booster to the back port on your carb and run the pvc to the manifold somewhere. The pvc doesn't need as much vacuum as the booster does.
that's a single plane intake which lack low end torque and are really only good over 3000 rpm.....any reason why your using a single plane?
