I am the new owner of a 1985 Monte Carlo SS, here are the specs on the car:
350 4 bolt main
Dart S/R Heads
Bored .30 Over
Flat top pistons
300hp cam
Holley 650 carb
700r4 trans
Stage 2 shift kit
4.10 spooled rear end
Now, I have a couple questions. Firstly, I've come to notice that if I stomp on the brakes at fairly fast speeds or if I take a turn fast, the car will stall. It has no stalling issues under normal operation or anything, pretty much just on emergency stops (standing on the brakes at 60KM/H) or taking turns very fast. Is this normal operation for a carbed 350? The last 350 I had was TBI, and the last carbed vehicle I had was a 1990 YJ years ago.
Second question, because of the flat top pistons should I use 89 or 91 octane gas? Or is the regular cheap stuff good enough?
Thirdly, can I hook up the stock speedo to the 700r4? Will a stock speedo cable for an '85 monte carlo hook up to the trans?
And lastly, I'm looking at un-spooling the rear end. I may go open or posi, not sure yet. This rear end is 7.5" 10 bolt, right? What is the spline count for the axles? I was told the P.O. put stronger axle shafts in it, would that have changed the spline count or would it still be the same as stock?
Any help would be greatly appreciated!
350 4 bolt main
Dart S/R Heads
Bored .30 Over
Flat top pistons
300hp cam
Holley 650 carb
700r4 trans
Stage 2 shift kit
