Well, the smog pump may trigger a check engine light as the diverter valve is computer controlled, and removing the A/C compressor is OK so long as you seal the lines in case you wish to put it back in at a later time.You could also find a used R4 compressor with a V belt clutch and replace yours.Then you could have the A/C for probably around $100 with a new condenser, R134a cycling switch ( Napa), refrigerant, flush and orifice tube. Racing is not harmful to your car, by the way, unless you are stupid. I have run my Frontier at the drag strip numerous times and it has managed to go 262k city miles so far and uses no oil, and still has good compression ( 160psi all 4 cyl.).It's all in how you care for your vehicle. Heck, I went 200k on the original clutch and relentlessly power shifted it while using it as a pizza delivery truck since it was new.
