Quick question
bigt0006
36
6
Can you install a remote starter on a cutlass supreme. It has a 307 in it
Not really unless you put a fuel injection system on it.
If you rigged up a remote that operated a solenoid that blipped the throttle once to set the choke and give the carb a squirt of gas you could.
You could also do it if your engine is already warmed up from a previous drive and it would start up without having to blip the throttle.
I am a sure a guy I knew with Dodge used a solenoid to start it cold. I dumped my 78 1/2 ton for my 94. Not only 4x4 but EFI and command start in -40 kicks *ss. No difference in mileage but starting from house is very nice.
injection would make it alot easier.
I mean ive had carbed motors that didnt care about the weather it would start everytime but that was with leaky fuel bowls and like 20 initial timing so yea lol it was like it was priming itself then just hit the key and bam not the right way to go about it at all
Rig a button to start it then rig another to pump the throttle from in the house lol
I was going to try this awhile back on a different car using a quadrajet and using a factory anti diesel solenoid and having it as an accessory on the remote key fob.
How about an old door lock solenoid to set the choke? You would need the extra channel on the fob or lose the trunk release convenience. Some remote starts have a pulse before start feature for the disarm wire. What brand starter are you wanting to use?
