Quote fir g body brakes???'s
scoti
1,978
3,402
Texas
So how much for this job for someone you know?
Only you know the correct answer. We provided some insight. Use that insight toward making a decision that you're comfortable with. Your $200 number would be fine....
I did a front end rebuild & brakes for a coworkers 73-87 vintage C10. He was quoted $1600 for just the brakes. I got it all done for a little over half that price (parts & labor).
81Regal
1,557
485
83
Terril Iowa
The OP never mentioned who was supplying the parts, $200 would be fair if all the parts are supplied, but you could burn through most of the $200 if parts need to be purchased.
9,614
12,683
I'd say if you are confident in doing the job and happy with $200 and your customer is satisfied with the price then go for it.
Keep in mind things don't always go as smooth as planned and that couple hours could end up being a lot more and make sure everything needed is already on site before you start, parts store runs in the middle of a job are no fun.
scoti
1,978
3,402
Texas
He has all the parts
This.
Verify part numbers before the work date. Nothing worse than getting started & having to scramble in the midst of the work.
