Rad supports?
Bernhard
129
What year Pontiac and Buick Alum Rad supports fit the 81 to 88 cutlass? Does any one have pics of all the rad supports? Thanks.
I know mine came from a 1980 4 door buick century.
Mine came from a 1978 Pontiac Grand Am (the car was loaded with options).
Doug
FYI............Mine did not have the large "A" stamped in it, just the little "A" by the headlight opennings.
Found mine in an early Regal with gas motor. I got it for free because I was buying some other stuff and the owner threw it in with the other stuff I was getting. I check for one on every Gbody I ever come across in junkyards or being parted out. It's very easy to check quickly without even popping the hood. If you look underneath and see rust on the bottom of the support, it's not aluminum. Now if you don't see or can't see any from the bottom, then pop the hood and get a better look. Again, if there's rust, move on. Check every Gbody because you never know where one might be.
